The status bar
The status bar is located at the bottom of the drawing area.
- It shows tool tips when you hover over a tool button on the status bar.
- It allows to enter command names and prompts command options when the command window is closed.
- It displays the current state of entity settings: layer, color, line style... and
allows to edit these settings.Note: These are turned off in any workspace by default.
- It displays the current dim style and text style and allows to set them.
- It displays the current state of drawing aids, such as entity snap, and allows to toggle them on/off.
Click the small black down arrow at the right side of the status bar to manage the display of the fields.
