RULERTEXTCOLOR system variable
Ruler Text Color
Specifies the color of the text on the ruler if the RULERDISPLAY system variable is on.
Type: |
String |
Saved in: |
Registry |
Default value: |
#c8c8c8 |
Possible values: |
RGB color code Hex color code Index color code |
A new value for the variable can be entered in the command bar.
