XLOADCTL system variable
Xref load control
Not supported yet. Specifies xref demand-loading and determines whether a copy or the original drawing is opened.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 2 |
Default value: |
1 |
Possible values: |
0: Turn off demand-loading; the entire drawing is loaded 1: Turn on demand-loading; referenced drawings are kept open and locked 2: Turn on demand-loading; copies of referenced drawings are opened and locked; referenced drawings are not locked |
