-ARRAYCLOSE command
Exits the associative array editing state.
Exits the associative array editing state, prompting at the Command line to save or discard the changes made to the array’s source entities.
Note: This command is available only after an associative array is
checked out with ARRAYEDIT command, Source option.
Options
- Yes
- Saves the changes made to the source entities of the array and then exits the array editing state.
- No
- Exits the array editing state and discards all changes, thus returning the array to its original state.
