-BEDIT command
Edits the entities that make up a block.
Edits the entities that make up a block in Block Editor environment, after introducing the name of the block to the Command line. Optionally creates a new block.
Method
There are two methods to use -BEDIT command:
  • Edit an already existing block.
  • Create a new block.
Options within the command
Block name
Enter a block name to open the Block Editor environment and start editing.
Note: Enter an unused name to create a new block.
Lists the existing blocks.
