-BLOCK command
Groups entities into a block.
Alias: -B
Method
Specify whether the block will follow annotative scaling and match the orientation of the viewport.
Note: Optionally, include REFERENCECURVES during the selection
of entities which allows to automatically align a block during insertion.
Options within the command
- Name for new block
- Specifies the name of a new block.
- Lists the names of blocks already in the drawing, so that an existing name won’t be used.
- Insertion point for new block
- Pick a point in the drawing or enter X, Y and Z coordinates.
- Annotative
- Specifies if the block will follow annotative scaling.
- Orient relative to sheet in paper space viewports
- Determines if the annotative blocks match the orientation of the layout.
