-BMINSERT command
Inserts sheet metal form features and components in the current drawing.
Inserts sheet metal form features, mechanical and BIM components in the current drawing.
Note: This command inserts a *.RFA file as a BIM
component.
This command operates at the Command line. Enter the path of the file to be inserted and choose one of the options. For more details about the options see BMINSERT command.
