-BOUNDARY command
Creates closed polylines from bounding entities.
Alias: -BO
Create closed polylines, defined by surrounding entities using the Command line. Options
allow you to pick an internal point, specify the boundary set, and detect islands. See
the BOUNDARY command to access similar functionality using a dialog box.
Methods to create a boundary
There is one method to begin creating a boundary:
- Internal point
- Internal point
- Begin creating boundaries by specifying a point inside an enclosed area for which you want to create a boundary. You can continue picking additional points until you press Enter to end the command.
Options within the -BOUNDARY command
After you begin creating boundaries, the following options may be available:
- Advanced
- Choose to modify boundary options or island detection.
- Boundary
- Specify where BricsCAD should search for entities that
make up the boundary.
- New: create a new selection set of entities that make up the boundary.
- Everything: select all entities in the current viewport.
- Island
- Specify the island detection. An island is an enclosed
area inside a boundary.
- Yes: treat every island as a boundary.
- No: create a boundary of only the outermost entities.
- Outer only: ignore the innermost areas. A boundary is created between the outermost area and islands.
- Exit
- Return to the previous prompt.
- Undo
- Undo the last internal pick point and continue picking points to specify additional enclosed areas.
