-DESIGNTABLEEDIT command
Edits design tables.
Note: This command can be entered transparently during the
commands (‘designtable).
Options
- eXport
- Exports the content of a design table entity in .csv format file.
- Replace
- Replaces the content of a design table with data from a .csv format file.
- Delete
- Deletes a design table.
- Configurations
- Creates, removes, or views configurations.
- Save current
- Creates a new configuration as a copy of an existing one.
- Remove
- Removes a configuration.
- ? to list
- List the names of design tables attached to the current drawing.
- Parameters
- Manages parameters:
- Unlink
- Unlinks parameters from the design table.
- Link
- Links parameters to the design table.
- Clear expressions
- Clears expressions (values and formulae) from parameters.
- ? to list columns
- Lists parameters.
- Apply configuration
- Creates a new row using the current values of variables.
- ? to list
- Lists design tables attached to the current drawing.
