-LAYER command
Manages layers through the Command line.
Alias: -LA
Creates layers and layer states and changes their properties.
Note: The current layer cannot be turned off and frozen.
Options within the command
Lists the names of layers in the current drawing.
New layer
Creates new layers.
Note: You can create several new layers by separating each name with a comma (,).
Make new current layer
Creates a new layer, and then makes it current.
Set layer as current
Sets a layer as the current one.
Rename
Renames the layer.
Color
Changes the color of layers.
Linetype
Changes the linetype of layers.
LineWeight
Changes the lineweight of layers.
TRansparency
Sets the entity transparency factor between 0 (fully opaque) and 90 (fully transparent).
MATerial
Sets the material property for all entities on the layer.
Plot
Changes the plot status of layers.
stAte
Manages layer states.
Save
Saves the current layer state.
Restore
Restores a saved layer state.
Edit
Edits a saved layer state.
reName
Renames a saved layer state.
Delete
Deletes a saved layer state.
Import
Displays the Import Layers States dialog box, which allows you to import a layer state from a file into the current drawing.
eXport
Exports a saved layer state in the current drawing to a layer state file.
turn layer ON
Turns layers on that were previously turned off.
turn layer OFf
Turns layers off to hide their entities from view.
Freeze
Freezes layers so that they are hidden from view.
Thaw
Thaws layers that were previously hidden with the Freeze option.
LOck
Locks layers so that their entities remain visible but cannot be edited.
Unlock
Unlocks layers that were previously locked.
