-LINETYPE command
Loads, sets, and creates linetypes in the Command line.
Alias: -LT
Method
You can create a new linetype by specifying a description (up to 47 characters long) and a linetype definition.
The linetype definition consists on a series of numbers separated by commas:
  • Dashes: are shown by positive numbers.
  • Spaces: are shown by negative numbers.
  • Dots: are shown by number zero.
Note: After creating a new linetype, you need to load it to be accessible.
Options within the command
Displays the Select Linetype File dialog box, which allows you to select a LIN file.
Create
Displays the Create or Append Linetype File dialog box, which allows you to select a LIN file to add a new linetype.
Load
Displays the Select Linetype File dialog box, which allows you to load a linetype definition.
Set
Sets current a loaded linetype.
