-LMAN command (Express Tools)
Saves, edits and restores layer states via the Command line.
Options within the command
Lists the available layer states.
Import
Opens the Import file name dialog box, which allows you to choose a .lay file to open.
Export
Opens the Export file name dialog box, which allows you to export the selected layer state to a .lay file format.
Save
Saves the current layer status.
Restore
Restores the layer settings of the mentioned layer state.
Delete
Deletes the mentioned layer state.
reName
Rename a saved layer status by specifying the old name and the new name.
