-OBJECTSCALE command
Adds or removes scale factors.
Adds or removes scale factors used with annotative entities through Annotation Object Scale dialog box.
Note: Annotative scaling adjust scale factors of annotative items, such as text and hatch patterns, to match the plot scale.
Options within the command
Select annotative entities
Select one or more items using any selection method.
Note: Write all in the Command line to select all entities in the drawing. The program filters out ineligible entities automatically.
Add
Adds annotation scales to the selected annotative entities.
Note: Enter ? to list the annotation scale factors available.
Delete
Deletes annotation scales from the selected annotative entities.
Displays a list of available annotation scales as defines in the scale list.
Note: See SCALELISTEDIT command.
