-POINTCLOUDDELETEITEM command
Deletes point cloud files.
Deletes point cloud files from the cache through the Command line.
Note: It also removes all the insertions (if any) of that point cloud in the current drawing.
Method
Enter the index of the point cloud to delete it.
Note:
- You can separate indexes by commas to delete multiple point clouds.
- Type All to delete all.
- The cached point clouds are listed in the Command line history.
