-POINTCLOUDREFERENCE command
Attaches point cloud files to the current drawing.
Attaches point cloud files to the current drawing through the Command line.
Methods
There are two methods:
  • Import a new point cloud.
  • Load from cache.
Options within the command
Cache
Allows you to enter the index of the point cloud to attach it to the current drawing.
Note: The valid cached point clouds are listed in the Command line history.
New
Attaches a new point cloud to the current drawing.
Inputdata
Allows you to specify the point cloud link to attach to the current drawing.
Toggle geotags
Toggles between using or ignoring geotags.
Enter translation vector
Allows you to enter the translation vector coordinates or specify it on the screen.
Rotation angle
Allows you to enter the rotation angle or specify it on the screen.
Scale factor
Allows you to enter the scale factor or specify it on the screen.
