-PSETUPIN command
Imports page setup definitions.
Imports page setup definitions from another drawing through the Command line.
Note: Page setups define how a drawing is printed and are used
by the Print and Publish commands.
Method
Run the command to open the Select Page Setup From File dialog box.
