-REDIRMODE command (Express Tools)
Sets the type of entities you want to find and replace the directories from via the Command line.
Method
Specify the type of entities to be included when using the REDIR command, separated by comma. There is no need to type the complete word, for example, s, x, i, r are valid entries.
Note: Type * to specify all type of entities.
