-VIEW command
Controls named views.
Alias: -V
Creates and sets named views in the current viewport, and deletes named views from the drawing.
Every viewport can show a different view in model and paper space.
Options within the command
Enter ? to list the existing views in the current drawing.
Enter Delete, Save and Restore options to perform the appropriate action.
- Orthographic
- Set a standard orthographic view point in the current viewport -- either the Top, Bottom, Front, BAck, Left, or Right view.
- TWist
- Rotate the current view about the Z axis in the direction set by the ANGDIR variable.
- Window
- Save a windowed area as a named view.
