-XREF command
Attaches and detaches DWG files.
Alias: -XR
Controls DWG drawing files that are attached to the current drawing (short for external reference).
Options within the command
? to list external references
Lists the names and paths of attached drawings, if any, and their statuses.
Attach
Opens the Select File to Attach dialog box to select a DWG file to attach.
Overlay
Opens the Select File to Overlay dialog box to select a DWG file to overlay.
Bind
Copies the contents of the attached drawing to the current drawing as a block reference.
Note: The BINDTYPE system variable defines how the Xref layers/objects will be brought in the current drawing.
Detach
Removes attached drawings.
Path
Changes the path (drive and folder) to the source DWG file, in case the original path no longer points to the file.
Reload
Reloads the attached drawing, after its content have changed.
Unload
Hides the attached drawing, but keeps it attached.
