3DFACE command
Draws 3D 4-edged faces.
Icon:
Alias: 3F, FACE
Draws 3D 4-edged faces with optional invisible edges, by entering values in the Command line or picking points in drawing space.
Options within the command
select Invisible edge
Makes the next edge invisible.
Note: The edge appears invisible in the wireframe visual style.
