3DMESH command
Creates 3D surface meshes.
Icon:
Alias: MESH
Creates 3D surface meshes by entering the number of vertices and their position.
Options within the command
- Number of vertices in M direction (between 2 and 256)
- Specifies the number of vertices in the primary direction.
- Number of vertices in N direction (between 2 and 256)
- Specifies the number of vertices in the secondary direction.
- Position of vertex (M,N)
- Specifies the position of the vertex.
Note: 3D meshes can be edited directly through grips.
