ACISIN command
Imports .sat or .sab files into the current drawing.
Icon:
Opens the Open an ACIS file dialog box to select a .sat or .sab file to import into the current drawing.
Note: The ACISIN command ignores the INSUNITS system variables of the .sat and .dwg files, so one unit of the imported SAT or SAB file is always converted to one DWG drawing unit.
