ACISOUT command
Exports solid and surface models in ACIS format for use by other solid modeling programs.
Icon:
Opens the Create an ACIS file dialog box to export 3D solids and surface entities in ACIS format, either in human-readable ASCII .sat or compact binary .sab format. Exported files can be shared with other 3D CAD programs capable of solid modeling or analyzing solid models.
Note: The scale factor stored in the file is always 1.
