AI_CONE command
Creates a 3D polygon mesh in the shape of a cone.
Icon:
描述(D)
Creates a 3D polygon mesh in the shape of a circular or elliptical cone. Choose from a combination of options including center, radius, diameter, height, axis endpoints, apex, and number of segments.
  1. 中心(C)
  2. 高度
  3. Segments
  1. Base diameter
  2. 底部半径
  3. Top diameter
  4. 顶部半径
  1. Apex
  2. Ellipse axis
  3. Other axis
Methods to create a cone
This command has 2 methods to begin creating a cone:
  • Center of base of cone
  • Elliptical
Begin creating a circular cone by specifying the center of the base then:
Radius of base
Specify the radius of the base of the cone.
Additional option: [Diameter]
指定圆锥体高度
Specify the height of the cone.
输入分段数目
Specify the number of isolines used to simulate the cone’s curved surface. The default is 16.
Elliptical
Begin creating an elliptical cone by specifying the first end of the ellipse axis then:
Additional option: [Center]
指定椭圆轴第二端点
Specify the second end of the ellipse axis.
Other axis
Specify the radius of the other axis.
指定圆锥体高度
Additional option: [Apex]
输入分段数目
Options within the AI_CONE command
After you begin creating a cone, the following options may be available:
Diameter 
Specify the diameter of the cone’s base or top.
中心(C)
Specify the center of an elliptical base.
Apex
Specify the location for the top of the cone.
