AI_CYLINDER command
Creates a 3D polygon mesh in the shape of cylinder.
Icon:
Creates a 3D polygon mesh in the shape of a circular or elliptical cylinder. Choose from a combination of options including center, radius, diameter, height, axis endpoints, and number of segments.
Methods to create a cylinder
This command has 2 methods to begin creating a cylinder:
- Center of base of cylinder
- Elliptical
- Begin creating a circular cylinder by specifying the center of the base then:
- Radius of base of cylinder
- Specify the radius of the cylinder.
- Height of cylinder
- Specify the height of the cylinder.
- Number of segments
- Specify the number of isolines used to simulate the cylinder’s curved surface. The default is 16.
- Elliptical
- Begin creating an elliptical cylinder by specifying the first end of the ellipse axis then:
- Second end of ellipse axis
- Specify the second end of the ellipse axis.
- Other axis
- Specify the radius of the other axis.
Options within the AI_CYLINDER command
After you begin creating a cylinder, the following options may be available:
- Diameter
- Specify the diameter of the cylinder.
- Center of second end
- Specify the center for the other end of the axis to create an oblique cylinder.
