AI_CYLINDER command
Creates a 3D polygon mesh in the shape of cylinder.
Icon:
描述(D)
Creates a 3D polygon mesh in the shape of a circular or elliptical cylinder. Choose from a combination of options including center, radius, diameter, height, axis endpoints, and number of segments.
Methods to create a cylinder
This command has 2 methods to begin creating a cylinder:
- Center of base of cylinder
- Elliptical
- Begin creating a circular cylinder by specifying the center of the base then:
- Radius of base of cylinder
- Specify the radius of the cylinder.
- 指定圆柱体高度
- Specify the height of the cylinder.
- 输入分段数目
- Specify the number of isolines used to simulate the cylinder’s curved surface. The default is 16.
- Elliptical
- Begin creating an elliptical cylinder by specifying the first end of the ellipse axis then:
- 指定椭圆轴第二端点
- Specify the second end of the ellipse axis.
- Other axis
- Specify the radius of the other axis.
- 指定圆柱体高度
- 输入分段数目
Options within the AI_CYLINDER command
After you begin creating a cylinder, the following options may be available:
- 直径(D)
- Specify the diameter of the cylinder.
- 指定圆柱体高度
- Specify the center for the other end of the axis to create an oblique cylinder.
