AIDIMSTYLE command
Applies and saves dimension styles.
Icon:
Saves the current dimension settings as a named style and applies a preset style to selected dimensions in the current drawing.
Method
There are two methods to begin working with dimension styles:
  • Apply a saved dimension style to dimensions in the drawing.
  • Save dimension settings in the current drawing as a named style.
Options within the command
Apply
Apply an existing dimension style to one or more dimensions.
Note: Use the '-DIMSTYLE command transparently during this command to list the names of dimension styles in the current drawing.
This overrides the changes made to dimensions with commands like AIDIMFLIPARROW and AIDIMPREC.
Save
Save the style properties of an existing dimension to a named style.
The properties of the saved style can be examined with the DIMSTYLE command.
