AI_DISH command
Creates a 3D polygon mesh in the shape of the bottom half of a sphere.
Icon:
Creates a 3D polygon mesh in the shape of the bottom half of a sphere. Choose from a combination of options including center, radius, diameter and number of segments.
Methods to create a dish
There is one method to begin creating a dish:
- Center of dish
- Center of dish
- Begin creating a dish by specifying the center of the dish’s open end then:
- Set radius of dish
- Specify the radius of the dish.
- Number of segments around dish
- Specify the number of isolines, perpendicular to the xy-plane, used to simulate the dish’s curved surface. The default is 16.
- Number of top-to-bottom segments
- Specify the number of isolines, parallel to the xy-plane, used to simulate the dish’s curved surface. The default is 8.
Options within the AI_DISH command
After you begin creating a dish, the following option may be available:
- Diameter
- Specify the diameter of the dish.
