AI_SPHERE command
Creates a 3D polygon mesh in the shape of a sphere.
Icon:
描述(D)
Creates a 3D polygon mesh in the shape of a sphere. Choose from a combination of options including center, radius, diameter, and number of segments.
Methods to create a sphere
There is one method to begin creating a sphere:
- 指定圆球体中心点
- 指定圆球体中心点
- Begin creating a sphere by specifying the center then:
- Set radius of sphere
- Specify the radius of the sphere.
- 输入经线分段数目
- Specify the number of isolines, perpendicular to the xy-plane, used to simulate the sphere’s curved surface. The default is 16.
- Number of latitudinal segments
- Specify the number of isolines, parallel to the xy-plane, used to simulate the sphere’s curved surface. The default is 16.
Options within the AI_SPHERE command
After you begin creating a sphere, the following option may be available:
- 直径(D)
- Specify the diameter of the sphere.
