ALIGN command
Moves, rotates, and scales entities to align with specified points.
Icon:
Alias: AL
Moves, rotates and scales entities in 2D or 3D space by specifying a set of alignment points.
Options
Select entities
Selects entities that are to be aligned.
Note: Do not select destination entities, otherwise they are also moved.
Specify first source point
Specifies the source alignment point.
Specify first destination point
Specifies the destination alignment point.
Note: Specify a second pair of source and destination points to move and rotate entities.
Specify second source point
Specifies the second source alignment point.
Note: If you press Enter at this prompt, the source object moves.
Specify second destination point
Specifies the matching destination point.
Note: Specify a third pair of source and destination points to move and rotate 3D entities.
Specify third source point
Specifies the source point for 3D alignment.
Note: Press Enter to move and rotate 2D entities.
Specify third destination point
Scale objects based on alignment points
Optionally scales the source object:
Yes
Scales objects relative to the picked points
No
Does not scale objects
