AMWELDSYM command
Creates a welding symbols.
Icon:
Methods
Select the object to attach the welding symbol and specify the points for its location.
- There are two use cases:
- When creating a new drawing that will contain mechanical
entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical
entities
- Open an existent ACM drawing and you can start special symbols creation.
entities:
Note: These symbols are compatible with the legacy AutoCAD
Mechanical application.
Note: The symbol will be added to the AM_5 layer.
Note: After opening a drawing that contains mechanical
entities, filling other drawings with mechanical-related data will be done
on-demand in contrast to previous versions. It will be possible when a user
copies the mechanical-related entities to the vanilla drawing. In the case of
copying, entities that are not related to the mechanical data, a vanilla drawing
will not be filled with mechanical data.
After creating the symbol prototype with the AMWELDSYM command, you can configure the exact welding symbol's properties from the Properties panel:
Symbol
- All Around
- Toggles the visibility of the All Around symbol in the welding symbol.
- Field weld
- Toggle the visibility of the Field weld symbol in the welding symbol.
- Note tail
- Displays the state of the note tail.
- Process notes
- Defines the process notes.
- Stagger
- Chooses between move and mirrored stagger for intermittent welds on both sides.
- Flip symbol
- Chooses between left and right aligned for weld symbol.
Requirements - Arrow side
- Weld type
- Defines the weld type from the below options:
- Small leg
- Defines the small leg dimension of the weld.
- Size
- Defines the size of the weld.
- Length
- Defines the length of the weld.
- Pitch
- Defines the pitch dimension for intermittent weld.
- Contour
- Defines the shape of the weld.
Requirements - other side
Defines the type and dimensions of the weld on the other side.
Leader
- Arrowhead
- Defines the default arrowhead type for welding symbols.
