ANIMATIONEDITOROPEN command
Opens the Animation editor panel.
Icon:
Opens the Animation editor panel to display it in the current workspace. The Animation editor panel appears at the same size and on the same location as it did before it was closed or collapsed. Like any other dockable panel, the Animation editor panel can be either floating, docked or stacked.
