ARCTEXT command (Express Tools)
Adds text aligned with a selected arc.
Icon:
Adds text aligned with a selected arc or edits the text of an existing arc aligned text entity.
Method
Select an arc or an arc aligned text entity.
Note: You cannot use this tool with splines, polylines or circles.
The ArcAligned Text Workshop - Create dialog box opens, which allows you to customize the display of the text.
