ARRAYCLOSE command
Exits the associative array editing state.
Icon:
Exits the associative array editing state, displaying the Array Close dialog box to save or discard the changes made to the array’s source entities.
Note: This command is available only after an associative array is checked out with the ARRAYEDIT command, Source option.
Options
Yes
Saves the changes made to the source entities of the array and then exits the array editing state.
No
Exits the array editing state and discards all changes, thus returning the array to its original state.
Cancel
Closes the dialog box and stays in the array editing state.
