AUDIT command
Analyzes the integrity of the current drawing and fixes errors.
Icon:
Note: Set the AUDITCTL system variable to 1, to let Audit create an ASCII file describing problems and the action taken. This report, with the file extension .adt, is placed in the same directory as the current drawing.
描述(D)
Checks the current drawing for errors and optionally repairs the drawing. It removes duplicate ACIS attributes.
Options within the command
- 是
- Fixes errors, if BricsCAD® finds any.
- No
- Searches and reports errors in the drawing database but does not repair them.
