BEXTEND command (Express Tools)
Extends entities to entities nested in blocks and external references.
Icon:
Method
Choose one or more entities nested in blocks or external references to use as boundary entity (1). These are the entities to which the subsequently picked entities are extended.
Choose the entity to be extended (2). When another end of an entity could be extended to a boundary, BricsCAD extends the closest end to your pick point.
- Boundary entity
- Entity to be extended
- Extended entity
Note: Switch to trim mode: press and hold the Shift key to select the part of an entity to be trimmed at the intersection with the nearest boundary entities. See the BTRIM command.
Options within the command
- Fence
- Selects all entities that cross the selection fence. The selection fence is a series of temporary line segments. The selection fence does not form a closed loop.
- Crossing
- Selects entities within and crossing a rectangular area defined by two points.
- Edge mode
- Toggles between Extend and No extend.
- Projection
- Specifies the projection method used when extending objects.
- eRase
- Deletes selected entities.
