BIMALIGNSECTIONBLOCKS command
Aligns section blocks in model space.
This command realigns section results based on SECTIONRESULTINTERVAL system variable.
Method
Aligns BIM section blocks in the model space of generated section blocks drawing.
Note: BIMSECTIONUPDATE identifies if
overlap between generated section blocks happened in model space and suggests
calling BIMALIGNSECTIONBLOCKS in this case.
