BIMANALYTICALMODEL command
Creates an analytical model from a fully classified BIM model.
Allows you to generate an analytical model from a full 3D model of a structure.
Method
The command opens the Allowed Deviations From Center Axis dialog box and starts with an automatically generated proposal but allows users to further adapt the model.
The automatic proposal will try to minimize rigid links (eccentricities) as much as possible by shifting, extending and even rotating some axis lines. The number of such changes can be controlled by the deviation settings.
Note: The generated proposal can be modified afterward by
using the options inside the Allowed Deviations From Center
Axis Dialog Box.
Options within the command
- Visual settings
- Opens the Visual settings dialog box. Allows to tick and untick different features of axes and nodes to highlight (in yellow) the axes and nodes that match these features. Also, the size of the disks representing the nodes can be changed from here.
- Recalculate
- Propagates the effect of a local change further, allowing modifications in the complete model. It will launch a global solution that again tries to minimize rigid links, respecting the changes made.
- Export and exit
- Exports the model to an IFC (*.ifc) or CIS/2 (*.stp) file .
Options in a node
- Select connected axes
- Selects the axes connected to the node.
- Remove
- Removes the node and the connected axes will be disconnected.
- Connect to axes
- Connects the node to a chosen axis (axes).
- Disconnect from axes
- Disconnects the node from a chosen axis (axes).
- Auto split
- Automatically splits the node into two nodes.
- Split along axis
- Manually splits the node along an axis.
- Merge
- Merges two or more selected nodes together.
Options in an axis
- Select connected nodes
- Selects the nodes connected to the axis.
- Remove
- Removes the axis.
- Connect to node
- Connects the axis to a chosen node.
- Disconnect from node
- Disconnects the axis from a chosen node.
- Add restrictions
- Adds a restriction on the axis.The restriction you can add depends on the restrictions that are already imposed.If there are no restrictions yet, you can add the following restrictions:
- Relax restrictions
- Relaxes a restriction on the axis.
