BIMATTACHSPATIALLOCATION command
Attaches or removes a spatial location to/from a selection of entities.
Icon:
Method
Run the command and choose one of the location numbers or choose to attach or unattach locations.
Options within the command
- Auto attach locations
- Allows you to automatically assign a spatial location. If necessary, new building(s) and stories are created in the Building and Story Manager dialog box.
- Unattach current location
- Allows you to remove the current spatial location from a selection set (including the Space property).
- Select space
- Allows you to assign a space to a selection of entities by first selecting the entities and then the space to be assigned.
Note: Assigning a Space property to a building element
overrides the element's Story and Building properties
with those of the space.
