BIMCLASSIFY command
Classifies an entity and gets a name and an internal unique GUID (= globally unique identifier).
Note: The GUID is maintained even when the BIM classification
changes.
Any dwg entity can be given a classification.
Icons:
Method
Select the entities to classify or press Enter to classify the entire drawing.
The BIM elements definition are detailed in the Classify as BIM element dialog box.
Options
- Wall
- Classifies the selection as walls.
- Column
- Classifies the selection as columns.
- Slab
- Classifies the selection as slabs.
- Beam
- Classifies the selection as beams.
- wIndow
- Classifies the selection as windows.
- Door
- Classifies the selection as doors.
- sPace
Classifies 2D and 3D entities as spaces. (IFC Spatial Structure Element)
Converts BIM rooms to BIM spaces.
- buiLding
- Classifies 3D entities as buildings. (IFC Spatial Structure Element)
- sTory
- Classifies 3D entities as stories. (IFC Spatial Structure Element)
- building Element
- Classifies the selection as unspecified building elements.
- Xref
- Classifies the selection as External References.
- Other
- Allows to classify the selection or convert the selection to a block and
classify the block reference.Note: Displays the Classify As Bim Element dialog box.
- Auto
- Automatically classifies the selected entity or entities.Note: This is the same as running BIMIFY command.
- stRuctural
- Classifies the selection as Building Structure Elements.
- Unclassify
- Removes all BIM data from the selected entities.
