BIMCLASSIFY command
Classifies an entity and get a name and an internal GUID (= globally unique identifier).
Any dwg entity can be given a classification.
Icons:
方式
Select the entities to classify or press Enter to classify the entire drawing.
The BIM elements definition are detailed in Classify as BIM element dialog box.
选项(O)
- 墙
- Classifies the selection as walls.
- 列
- Classifies the selection as columns.
- 板
- Classifies the selection as slabs.
- 梁(B)
- Classifies the selection as beams.
- wIndow
- Classifies the selection as windows.
- 门
- Classifies the selection as doors.
- 空间(P)
Classifies 2D and 3D entities as spaces. (IFC Spatial Structure Element)
Converts BIM rooms to BIM spaces.
- 建造(L)
- Classifies 3D entities as buildings (IFC Spatial Structure Element)
- 楼层(T)
- Classifies 3D entities as stories (IFC Spatial Structure Element)
- building Element
- Classifies the selection as unspecified building elements.
- 外部参照
- Classifies the selection as External References.
- 其他
- Allows to classify the selection or convert the selection to a block and classify the block reference.Note: Displays the Classify As Bim Element dialog box.
- 自动
- Automatically classifies the selected entity or entities.Note: This is the same as running BIMIFY command.
- 结构(R)
- Classifies the selection as Building Structure Elements.
- 取消分类
- Removes all BIM data from the selected entities.
