BIMCOPY command
Creates copies from the planar faces of 3D solids.
Icon:
Creates copies from the planar faces of 3D solids, and the sides and ends of linear solids.
Method
Specify a distance to create copy.
Note: You can specify a distance in the dynamic dimension
field and right-click to create a single copy.
Options within the command
- Copy
- Creates copies.
- Repeat
- Repeats the copy using the same displacement. Move the cursor in the displacement direction.
Note: Move the cursor in the displacement direction. The
further you move away from the source solid, the more copies are created.
- Number
- Creates a number of copies you want to have in your model.
- Accept
- Accepts the current distance you entered in the dynamic dimension field.
