BIMCREATEDETAIL command
Creates a detail and saves it in the library.
Method
Select reference solids, detail entities and section in the Create detail dialog box.
Options within the command
- Accept
- Accepts the detail area. Displays the Save detail dialog box, which allows you to save the detail.
- Reject
- Does not accept the detail.
- Inflate first
- Expands the sensitive zone to include similar solids which are not connected yet in the model. The edges of the initially detected detail are moved outward over a specified distance.
