BIMCREATEDETAIL command
Creates a detail and saves it in the library.
BricsCAD BIM
Method
Select reference solids, detail entities and section in the Create detail dialog box.
Options within the command
Accept
Accepts the detail area. Displays the Save detail dialog box, which allows you to save the detail.
Reject
Does not accept the detail.
Inflate first
Expands the sensitive zone to include similar solids which are not connected yet in the model. The edges of the initially detected detail are moved outward over a specified distance.
