BIMCURTAINWALL command
Creates a curtain wall.
Icon:
描述(D)
Creates a curtain wall, as a block, from the face of a 3D Solid.
方式
Select a face and create a grid.
Options within the command
- U向平板长度
- Sets the length of the panels in U direction (height).
- V向平板长度
- Sets the length of the panels in V direction (width).
- U向平板数量
- Number of panels in U direction (rows).
- V向平板数量
- Number of panels in V direction (columns).
- 宽度
- Defines the width of the curtain wall frame, mullions and transoms.
- 深度
- Defines the depth of the curtain wall frame, mullions and transoms.
- 玻璃厚度
- Defines the thickness of the glass panels.
- 连接类型
- Defines the type of the connections between horizontal and vertical mullions.
- 直的
- Creates a straight connection.
- 平滑
- Creates a smooth connection.
- 节点
- Creates a node connection.
- 删除定义实体
- Whether the selected source entity is retained or deleted depends on the value of the DELOBJ system variable.
