BIMCURTAINWALL command
Creates a curtain wall.
BricsCAD BIM
Icon:
Creates a curtain wall, as a block, from the face of a 3D Solid.
Method
Select a face and create a grid.
Options within the command
Length U panels
Sets the length of the panels in U direction (height).
Length V panels
Sets the length of the panels in V direction (width).
Number U panels
Number of panels in U direction (rows).
Number V panels
Number of panels in V direction (columns).
Width
Defines the width of the curtain wall frame, mullions and transoms.
Depth
Defines the depth of the curtain wall frame, mullions and transoms.
Glass thickness
Defines the thickness of the glass panels.
Connections type
Defines the type of the connections between horizontal and vertical mullions.
sTraight
Creates a straight connection.
Smooth
Creates a smooth connection.
Nodes
Creates a node connection.
Delete defining entities
Whether the selected source entity is retained or deleted depends on the value of the DELOBJ system variable.
