BIMFLIP command
Flips a starting face of a composition or mirrors/flips an insert.
Icon:
描述(D)
Flips the starting face from which the layers of a composition are set out, or mirrors an insert (e.g. a window or door) left/right or flips it inside/outside.
方式
There are two methods to flip entities:
- Left- right.
- 内外
Before:
After:
Note: The result is visible in drawings generated by the BIMSECTIONUPDATE command if a multi-layered composition is attached to the sectioned solid.
选项(O)
- Select BIM entity to flip
- Inserts, walls and slabs are accepted in the command.
- 左右
- Mirrors the insert about a vertical axis in the face of the solid.
- 内外
- Flips the insert to the opposite face of the solid.
