BIMFLOWCONNECT command
Creates a connection between flow segments.
BricsCAD BIM
Icon:
Creates a connection between flow segments, such as pipes or HVAC ducts.
Note: When more than 2 flow segments are selected, the axes of the selected segments must be coplanar. When multiple coplanar segments are selected, the connections are created. When two non-coplanar solids are selected, an extra connection element is introduced.
Options
Switch
Switches between possible connections.
Alternatives for circular flow segments:
Alternatives for rectangular flow segments:
Note: Press the Ctrl key to cycle through different types of connection. Hot Key Assistant must be set ON.
When the section of the selected flows is different, reducer elements are inserted.
Alternatives for reducers:
Note: The creation of bends, tees and reducers is controlled by related system variables.
