BIMFLOWCONNECT command
Creates a connection between flow segments.
Icon:
描述(D)
Creates a connection between flow segments, such as pipes or HVAC ducts.
Note: When more than 2 flow segments are selected, the axes of the selected segments must be coplanar. When multiple coplanar segments are selected, the connections are created. When two non-coplanar solids are selected, an extra connection element is introduced.
选项(O)
- 切换
- Switches between possible connections.
- 减速器
- When the section of the selected flows is different, reducer elements are inserted.
