BIMLINEARSOLID command
Creates a chain of linear solids.
BricsCAD Shape; BricsCAD BIM
Icon:
Options within the command
Last point
Press Enter to use the most recently specified point.
Follow
Draws the next linear solid at the same angle as the previous one.
Rectangular
Switches to a default rectangular profile.
Circular
Switches to a default circular profile.
Library
Opens the Profiles dialog box.
select in Model
Allows to select a profile in the model.
adJust profile
Allows to adjust the dimensions of the default rectangular and circular profile.
Note: For rectangular profile you may change the width and the height and for circular profile the radius.
Angle
Draws at a user-specified angle and distance.
Length
Draws at a user-specified distance and angle.
Undo
Erases the last linear solid.
Quarter turn
Rotates the profile 90° counter clockwise.
Rotate
Allows to rotate the profile by a user defined angle.
Positive values rotate the profile counter clockwise.
choose other Profile
Allows to use a different profile for the next linear solid.
